Hi. I Need to use Renault elv emulator on Scenic year 2004 ( older 250kb)
I tested both configuration jumper,open close, but no work. I know that also other Company emulators(like carlabinmo) no work older Scenic year 2004 version .
Have you any solution?
Renault esl emulator problem
- Been thanked: 1894 times
Re: Renault esl emulator problem
Of course.
Repair a car, your problem most likely is not a broken ESL.
Marcoco
Of course? Im not stupid i know what i did. Just fix by change motor inside and all Is ok . Is not the First time, i know this problem with old Scenic year 2004
Emulators not work with this version .
This elv version got a relay inside for reverse motor , other Renault elv ( where emulator work) got an ic For control motor.
May be some play with pullups / pulldowns necessary.
Emulator works with this kind of SCL without any problems.
To say more, it works with new type Renault / Nissan steering locks too. Just pullups on right wires necessary.
