Renault esl emulator problem
Marcoco
Postby Marcoco » 05 May 2020, 12:55
Hi. I Need to use Renault elv emulator on Scenic year 2004 ( older 250kb)
I tested both configuration jumper,open close, but no work. I know that also other Company emulators(like carlabinmo) no work older Scenic year 2004 version .
Have you any solution?
Re: Renault esl emulator problem
Postby Girts » 05 May 2020, 17:21
Of course.
Repair a car, your problem most likely is not a broken ESL.
Marcoco
Postby Marcoco » 07 May 2020, 13:41
Of course? Im not stupid i know what i did. Just fix by change motor inside and all Is ok . Is not the First time, i know this problem with old Scenic year 2004
Emulators not work with this version .
This elv version got a relay inside for reverse motor , other Renault elv ( where emulator work) got an ic For control motor.
Postby Girts » 07 May 2020, 23:44
May be some play with pullups / pulldowns necessary.
Emulator works with this kind of SCL without any problems.
To say more, it works with new type Renault / Nissan steering locks too. Just pullups on right wires necessary.
Return to “CARTOOLS”
