Passat B6 ELV Emulator
Doig5710
Postby Doig5710 » 23 May 2022, 05:00
Hello i ordered these for my B6 Passat
https://cartools.lv/Shop/product_info.p ... cts_id=186
and to program
https://cartools.lv/Shop/product_info.p ... cts_id=180
I got the data from the CCM and old ELV and tried to program into the emulator but have not had any success getting it to work, even tried swapping MAC ELV data around but still no luck
Have attached a photo of the data entered and note pad of data recovered from CCM.
Any help would be great.
Re: Passat B6 ELV Emulator
Postby Girts » 23 May 2022, 12:21
What LED activity says? Is there a long blink confirming key authorization?
Are there all 10 pins attached?
Doig5710
Postby Doig5710 » 31 May 2022, 07:59
When programing both ESL lights come on red one goes out then Key light comes on and goes out then green ESL light goes out, so I belive that means it's all good, then solder the jumper link and fit it, the leds come on and go off without flashing so I think that means it's ok as well.
I've managed to get it started though, deleted the internal ECU fault code from the immobilizer and it starts, if i also delete it from the CCM then it fails to start again so i must also have a faulty CCM as well as a failed ELV.
Thanks for the help though, emulator works perfect everytime if i leave the code in the CCM.
Users browsing this forum: tagiruk and 21 guests
