Ews3 emulator
bboctavian
Ews3 emulator
Postby bboctavian » 26 Jan 2022, 17:09
Hello, just i buy from cartools a ews3 emulator . my ecu is dde5
ecu bosch code: 0281011224
I need to know if this wiring diagram is good to connect the emulator
And after i need to cut the EWS wire from dde and disconnect the cas from the plug ?
thanks
Re: Ews3 emulator
Postby Girts » 26 Jan 2022, 20:01
Partially.
Must use "15".
bboctavian
Re: Ews3 emulator
Postby bboctavian » 27 Jan 2022, 10:03
Sorry i don't understand? 15 what ? 15 ignition ?
kesik
Has thanked: 5 times
Been thanked: 12 times
Re: Ews3 emulator
Postby kesik » 27 Jan 2022, 12:08
edc16 bmw pinout : 1 (+12v) (30) , 2 (GND) (31) , 7(IGN)("15"), 8 (K-Line) , 10 (EWS/CAS Line)
small plug
PROBGD
Re: Ews3 emulator
Postby PROBGD » 09 Jul 2022, 08:58
Hello mate did your EWS3 emulator for on DD5
Users browsing this forum: tagiruk, Yandex [Bot] and 36 guests
