IMMO EMULATOR FOR HYUNDAI /KIA
thanosxx
Postby thanosxx » 19 Aug 2019, 08:27
Hello.I try to install emulator on smatra2 HYUNDAI COUPE 2.000CC PETROL ENGINE
I know the pin of the car also I have a valid key ,also I read the key with tango and write the IDE page of tango and write this page(35B8AC11) IN id and the pin .I connect the emulator to ecu ,positive, ground and k line on pin 77 then solder the configuration point but the engine doesn't start .Is it the first time to try use this emulator ,can anyone help me? Thank you in advance
Re: IMMO EMULATOR FOR HYUNDAI /KIA
Postby Girts » 20 Aug 2019, 09:11
Follow instructions step by step, you must write complete key copy - pages 0 to 3 as in your original key. Write via pin code may not work.
Postby Daniulis » 20 Aug 2019, 10:04
What's the state of the LED on the emulator?
thanosxx
Postby thanosxx » 20 Aug 2019, 12:10
The led blink slow sometimes and sometimes blink fast ,I try to read pin reader but there is always the message line monitoring I have connect emulator ground ,positive when ignition is on and on pin 47 the k line cable pin 47 is immo line and 77 pin of ecu is k line
Return to “CARTOOLS”
