Everything looks fine.
So where is a problem? Car doesn't start? Or key isn't accepted? Alignment with DIS (or similar tool) successful? ISN match both together?
XPROG для этого CAS2
- Been thanked: 1929 times
Re: XPROG для этого CAS2
all ok but will not start I get error read with autocom
Error communication with ews
I can do that is immobilizer problem?
do immo off?
do immo off?
5 questions, answer got only to one of them. Unreasonable communication.
hello someone can lend a hand to modify the file to start the vehicle thanks and greetings greatly appreciate it
- Has thanked: 126 times
- Been thanked: 175 times
File not start
Mister i hate to be rude but..... unfortunately this job is not for you. Just leave it for someone who knows what te is doing because it is realy sensitive job and we cant stand behind your back and tell you what you are doing wrong. First when ytou read eprom and the size of eprom is 2 times smaller then it has to be and then you overrite it whith another one that is wrong you get deal CAS. From this point your choices are not so good. Just get another cas or something because if you cannot use progger properly nobody can help you. I hope you will not get mad at me for that but realy we dont know how to help you.
Hope this ends thip topic.
Hello again I keep with this theme this bmw e90 Someone can help me to start this car a salute
took 3 months for this car in the garage can someone please help me
- RADEON
- Has thanked: 383 times
- Been thanked: 306 times
Блин, уже бы официалам оттарабанил. CASы не золотые поди...
the cas is fine just has the wrong file encoding is only set or because it has no communication with ews everything else goes well
Do you have any clue what you are writing? Your english sucks big time.
