XPROG для этого CAS2
Been thanked: 1929 times
Re: XPROG для этого CAS2
Postby Girts » 22 Oct 2013, 08:22
Everything looks fine.
So where is a problem? Car doesn't start? Or key isn't accepted? Alignment with DIS (or similar tool) successful? ISN match both together?
hackbest
Has thanked: 2 times
Been thanked: 1 time
Postby hackbest » 22 Oct 2013, 08:25
all ok but will not start I get error read with autocom
Error communication with ews
I can do that is immobilizer problem?
do immo off?
Postby Girts » 22 Oct 2013, 09:27
5 questions, answer got only to one of them. Unreasonable communication.
hackbest
Postby hackbest » 22 Oct 2013, 09:48
I can do the problem is I do companions eeprom
hackbest
Postby hackbest » 23 Oct 2013, 11:01
hello someone can lend a hand to modify the file to start the vehicle thanks and greetings greatly appreciate it
hackbest
Postby hackbest » 26 Oct 2013, 18:13
Hello anyone I can lend a hand
Postby autolocksman » 27 Oct 2013, 11:39
Address to nearest specialized car service of your region
hackbest
Postby hackbest » 27 Oct 2013, 12:19
there must be some way to repair than the official serviceo
hackbest
Postby hackbest » 27 Oct 2013, 13:48
File not start
hackbest
Postby hackbest » 28 Oct 2013, 11:41
I have the file corrupt eeprom someone can look
Postby efka » 28 Oct 2013, 13:38
Mister i hate to be rude but..... unfortunately this job is not for you. Just leave it for someone who knows what te is doing because it is realy sensitive job and we cant stand behind your back and tell you what you are doing wrong. First when ytou read eprom and the size of eprom is 2 times smaller then it has to be and then you overrite it whith another one that is wrong you get deal CAS. From this point your choices are not so good. Just get another cas or something because if you cannot use progger properly nobody can help you. I hope you will not get mad at me for that but realy we dont know how to help you.
Hope this ends thip topic.
hackbest
Postby hackbest » 28 Oct 2013, 13:44
thanks
happens only file that has no communication with ews
hackbest
Postby hackbest » 05 Feb 2014, 23:08
Hello again I keep with this theme this bmw e90 Someone can help me to start this car a salute
took 3 months for this car in the garage can someone please help me
Busyman
Has thanked: 80 times
Been thanked: 53 times
Postby Busyman » 06 Feb 2014, 00:31
Buy new cas or refer to a specialist
Postby RADEON » 06 Feb 2014, 21:10
Блин, уже бы официалам оттарабанил. CASы не золотые поди...
hackbest
Postby hackbest » 09 Feb 2014, 01:26
the cas is fine just has the wrong file encoding is only set or because it has no communication with ews everything else goes well
Postby efka » 09 Feb 2014, 09:29
Do you have any clue what you are writing? Your english sucks big time.
Return to “Dashboards”
