FORD 4D immo emulator
Canfan
Has thanked: 3 times
Been thanked: 3 times
Postby Canfan » 18 Nov 2022, 10:05
Problem software says error wrong com Port.
But the K-Line interface is on com port 1
any one now the problem?
Canfan
Re: FORD 4D immo emulator
Postby Canfan » 18 Nov 2022, 12:45
i found the fault the 4D emulator software need a USB to serial interface with k-line.
I used the computer's internal serial com port with a Kline adapter that the software does not recognize
Postby Girts » 18 Nov 2022, 23:18
That happens.
Not a fault in software, problem is with your hardware drivers, hardware conflicts or hardware itself.
Standard baud rates used here, nothing exceptional.
Canfan
Postby Canfan » 28 Nov 2022, 09:29
Hello,
the emulator can now be used without any problems, but if I enter the key data in the emulator, but the imo go not off
pssword: 03
users: 00
Key: 0000000000
Seed: 0000000000
resp: 00000000
these are the key data that I enter directly.
Postby Girts » 28 Nov 2022, 13:31
Key 0000000000 ?
Seriously?
Canfan
Postby Canfan » 29 Nov 2022, 10:03
I have a tool to read the key and it told me that
Postby Girts » 29 Nov 2022, 14:49
P4 (KEY PASSWORD) is write only, it is not readable using standard transponder machines.
Although it can be calculated...
Canfan
Postby Canfan » 09 Dec 2022, 10:22
I have test it with another Key with engine control unit
But the imo go not off
Key data from engine controal unit
pssword: 03
users: 00
Key: CDAD024781
Canfan
Postby Canfan » 09 Dec 2022, 11:12
found the error
the diagnostic software gave the wrong key
the correct key is 814702ADCD
Users browsing this forum: tagiruk, Yandex [Bot] and 37 guests
