-> HOME
EZS / IFZ / IMMObox emulator:
CAN bus bit rate: jumpers 1, 2:
open / open: 500 kb
open / short: 125 kb
short / open: 250 kb
short / short: 500 kb, configuration mode.
CAN bus terminator: jumper 3
If short, CAN bus is terminated by 120 ohm.
Configuration:
Emulator must be in configuration mode, jumpers 1 and 2 shorted. You can use any suitable CAN logger to store / read ECU password from emulator. Must use id 555 with data length 8 where first 4 bytes is password and last 4 bytes is inverted password. Emulator will respond with id 556 where first 4 data bytes is password, followed by 00 00 00 00. If data sent in frame 555 is not valid, actual value is returned.
examples:
to: 555 8 FF F1 FF AA 00 0E 00 55 - we are storing ECU password FFF1FFAA
to: 555 8 1B 55 86 C8 E4 AA 79 37 - we are storing ECU password 1B5586C8
to: 555 8 00 00 00 00 00 00 00 00 - data not valid for store, actual value returned:
Status led blink patterns:
10000000 - 1x blink, 7x pause: emulator is ready to communicate with ECU
10100000 - code from ECU received, response transmitted
11111111 - led permanently on: ECU accepted response, ready to start.
10101010 - response not accepted by ECU, not ready to start (wrong password?)
