Toyota RAV4 2-byte immo systems
bokilee
Has thanked: 2 times
Postby bokilee » 14 Feb 2024, 12:36
Hi, I recently order 2-byte immo systems emulator (Girts help me on this). I'm trying to use it on the:
Toyota RAV4
Engine: 2000CCM 3S-FE
Year 2000
ECU is one wthout eeprom and only thing that I have in my hands are the ECU itself.
I did this things till now:
Program the emulator with code 3000 for RAV4. LED lit x4(Girts help me on this also)
I solder the jumper on the emulator board:
I make connection for the emulator:
I make this connection for the ECU:
ECU have constantly +12V on the pin batt.
When I power up ECU on the +12V from the main relay pin, LED lit x1(short) and then lit x1 (cca 5 times longer). When I remove supply (not from batt pin) and put it again LED only lit x1(short), but if I did this x4 in a row 4th time I have again LED lit x1(cca 5 times longer).
If I remove power supply from batt pin and from main relay pin, then LED every time I put supply back lit x1(short) and then lit x1 (cca 5 times longer).
My question is this normal behavior of the LED\emulator? (I do not have car to test it if car starts)
Thanks.
Re: Toyota RAV4 2-byte immo systems
Postby Girts » 14 Feb 2024, 17:24
ECU has some capacitors inside.
LED means - ECU request.
If ECU is in already authorized state it isn't requesting IMMO again.
If you haven't any diagnostic tools you can play with CODE. Store different one (invalid CODE) and observe what happens then with LED on emulator board.
