Nissan Nats emulator, I am going to carry out work on a Denso 23710-BU721 ECU, this uses a NATS6 with BCM and Antenna letter L.
To configure the emulator, in the SW download link I downloaded NATS5-Config which is for K-Line and not NATS6 for Canbus of the emulator.
https://cartools.lv/Shop/product_info.p ... cts_id=121 (I think the SW in the link is wrong, it is not for NATS6)
Can you give me a link to download Nats6 Emulator SW configuration, I can't find it,
Thank you
SW CanBus Nats6 emulator Nissan
AutoKeyEcu
- Has thanked: 35 times
- Been thanked: 6 times
AutoKeyEcu
Re: SW CanBus Nats6 emulator Nissan
I found the SW NATS6 in MB can utilities,
check download link in SHOP emulator
thanks,
thanks,
Because for any CAN emulator you can configure using simple CAN logger (MBcan is an option!) usually there are no direct links in item description.
All MBcan related utilities are located here:
viewtopic.php?f=30&t=4761
AutoKeyEcu
I need ECU Pinout to put a Nats6 emulator, I think I am missing positives,
I have pinout gnd and Canbus controlled.
I would be missing some positives, since the emulator only gives an LED signal to turn on the contact, even if it says bad or good MAC, it does not give long or short flashes.
Or what is the best way to put the emulator on the workbench?
Nissan Almera Tino 5P2 D-YD22 4/2184 2005
Denso 23710 BU721 275800 3231 (64F7055F40+eep93c56)
AutoKeyEcu
