EWS3 emulator - Help
AutoKeyEcu
Has thanked: 35 times
Been thanked: 6 times
Postby AutoKeyEcu » 22 Jun 2023, 08:24
Hello, I have a problem, with the EWS3 emulators,
I do NOT have communication with the emulator.
and Script of the page. https://cartools.lv/Robin/page27.html
I use the VAGKKL cable, com3 or com4 port (you can change them without problems in drivers) I use Windows XP and 7, but it always tells me that the emulator does not respond to communication.
I know that I am using pinout in ecu correctly in a DDE (ECU BOSCH EDC15C4-8.35 0281010754 RANGE ROVER NNN000461 BMW 7791367)
previously I did a few successfully, but now I can't, I don't know what is happening. can be faulty emulators?
any other scrypt to change settings in pairing?
there may be the possibility of the VAGKKL cable, you can use the ¨(MBcan Cartools) because it also gives me problems.
Re: EWS3 emulator - Help
Postby Girts » 22 Jun 2023, 10:21
Delete all ftdi drivers from your pc, clean registry, reinstall again.
That usually happens if too much ftdi devices installed.
Another point - set latency timer to 2 instead of 16 by default
Another possibility - cloned ftdi chips and new drivers...
Users browsing this forum: Daniulis and 34 guests
