BMW DDE5 emulator
oost82
BMW DDE5 emulator
Postby oost82 » 26 Jan 2022, 21:13
Hi
Can anyone help me to set up the BMW DDE5 emulator.
I have EWS emulator installed and INPA.
These are the instructions for EWS:
"Configuration:
Launch configurator, write ISN, select mode and write these data into emulator by pressing button WRITE. It is possible to read back ISN and mode from emulator at any time.
Set emulator for alignment,
Set ECU for new start value.
Steps 2 and 3 are necessary only when EWS3 mode is used. In case of EWS2 car is ready to start immediately after writing correct ISN and EWS2 mode into emulator."
It does not allow me to "Set ECU for new start value" it gives me the following error: "not ok- wrong data", all the steps/functions prior to this seems to work.
I have also tried to go "set ECU for alignment" then use F1 function on INPA CAS-/EWS start value synchronization menu.
But then gives me the following message: "no free start value for enable open"
Thank you
Re: BMW DDE5 emulator
Postby Girts » 26 Jan 2022, 21:20
https://cartools.lv/Robin/page27.html
Read again and again...
If procedure fails - switch off, wait ~20 seconds, try again from step 2
By the way, there is no button DDE5 on setup utility, use INPA/Tool32 or whatever you have (ignore error screens!).
Return to “CARTOOLS”
