Cas3 issue with flash
jasonics_72
Hi great ppl , im having issue with 2 cas 3 black colour flash issues when reading i get 2.0Mb wen must b 512kb. eeprom is kb for both cas ,flash i get 2mb fie size .programmer is xprog m reads and writes .I have zedfull when i input the eeprom i cannot make keys under cas3 it says undefined,if i used cas3+ then tool accepts eeprom ,where can problem b as i never had issue making bmw keys either by icp or direct obd with zf. someone plz clarify me.
jasonics_72
Re: Cas3 issue with flash
LOL, no someone downgraded cas to make keys et voila car is dead. got a full ecu +cas3+ program ,magic car starts again.
jasonics_72
when ppl r still alive,they have tongue ,they act like mute. he should have told me someone came with chinese Xtool to add a key for cas3+ and messed up ,no need to downgrade cas 1ori key was present,what he did god knows.flash file was dead so was car,when he came with cas box and ask to make key,zzzzzfull did find errors ,so i clone ecu+cas from a good working one, edit the vin and car started with no issue. Manual g.b. Thanks ZZZfull will never sell it ,its an elite compare to shit chinese tool.
jasonics_72
I really think there was an easier way ,to wake up cas ,mcu had mask 0l15y -cas3+ when read zfull or bmw isn tool detects it as cas3 not +. but unfortunately nobody ask if he could help.Helping others is the best blessing u get in life.
jasonics_72 wrote:I really think there was an easier way ,to wake up cas ,mcu had mask 0l15y -cas3+ when read zfull or bmw isn tool detects it as cas3 not +. but unfortunately nobody ask if he could help.Helping others is the best blessing u get in life.
Cas3 + is not your biggest problem. Cas3 ++ is much worse, but never try to do cas3 +++ (triple plus). This is the product of the devil. It will die even if you just read the errors.
