HI,
I have Ford s max 2007
ecu:sid206 I need immo off
I have (FORD type1 CAN) immo emulator and have (CAN bus logger),some one can help me how to store SYNC into ECU
Can some one can help me step by step .
Thanks
http://cartools.lv/Shop/product_info.ph ... cts_id=126
http://cartools.lv/Shop/product_info.ph ... ucts_id=99
CAN bus logger,Ford sid206 immo off
Re: CAN bus logger,Ford sid206 immo off
Please post your ECU dump...
Or may be you already know these 8 bytes of SYNC ?
baubynis
Ecu eeprom
try 90EDA03EB73FB3A3 (not 100% sure).
must send 2 messages and observe results:
7FE (8) 01 90 ED A0 3E 00 00 00
7FE (8) 02 B7 3F B3 A3 00 00 00
By the way - what's wrong with car? What is a main reason to install emulator?
baubynis
baubynis
Can bus logger : read
nevver did this before ,not shure where I can write ,where is location in eeprom?
If the car is S-max (not C-max) then the immoblizer has been implemented in BCM
baubynis
But how to use immo emulator and how to Store SYNC into ECU with can bus logger , or where to write in to eeprom?
1- connect the emulator to the analyzer on table (use terminator if You work on 500 Kbps).
2- power the emulator with 12 volts.
3- send the frame with synchro data (SYNC) to the emulator, ID & DLC & DATA -> according to the emulator documentation.
4- observe the analyzer program window, the emulator will send back the currently saved synchronization (SYNC).
5- connect the emulator to ECU -> do power up both necessarily at the same time ! observe LED on EMU according to the emulator doc.
of course, remember about jumpers !
Enjoy
Enjoy
baubynis
analyzer is can bus logger?
have connect can hacker,but then do no what to do next, please help me to solve this problem ,
will pay you just need to fix and start the car with this eemulator.
Thanks
Thanks
You have already completed points 1 and 2, go to point 3 from my previous post !
baubynis
Can you help me to write SYNC ?
Try to write but not saving , can you help me with teamviewer to program it?
Regards Evaldas
Regards Evaldas
