Убил апарат во время обновления. Изначально был MU 0319 Сечас появляется зеленый экран и зависает на поиске метаинфы.
Судя по терминалу сначала пробует востановить себя, а потом ждет загрузку с диска
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]
CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_09422A
(0ms)
*** emergency FPGA loaded!
*** Old-fashioned mark found on IFS @0x1c0000: .zero=0x30000011
starting image @1c0000 ...
Startup: PL_qnx_startup-sh7785_09332A, built 2009/08/11_11-10-29_UTC
RAM : 128 MB @0x08000000
RAM : 128 MB @0x40000000
RAM : 256 MB @0x50000000
FLASH: 128 MB @0x00000000
FPGA IRQ: Interrupt Controller ID:33 Ver:2.1.0 ILVL:7 Lines:255
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v88046b20
intrentry_base = 8ffe5630, size=2176
copying intrentry code:
intrentry_code_buf = 88085f28
copy_size = 2432
final intrentry_base = 8ffe5630, size=2176
Welcome to QNX 6.3.2 (RL_qnx_os_632_PSP3_08493A) MMI3G Audi EMERGENCY SETUP 0946 2A
starting pci driver
*** init FPGA registers ***
starting dev-ipc for IOC
initialize IPC Driver
starting network driver
starting atapi driver - setup device /dev/cam0
[pcidma] finished.
starting devc-pty
Path=0 - XILINX ATAPI
target=1 lun=0 Direct-Access(0) - TOSHIBA MK6050GA Rev: TJ10
starting flash driver
starting SDCard driver
Unable to access "/dev/io-net/en5" (2)
starting with no network driver
Emergency IFS is started. Emergency app tries to restore
the application.
49169 running /usr/bin/devg-NVTIRM
DMA is Disabled
dma disabled, interrupt thread priority = 100
49171 running /sbin/io-media-nvidia
49172 running /usr/sbin/io-display
49173 running /usr/apps/MMI3GEmergencyApp
Emergency shell started, fix your system and restart again
discplayer_init: IN
nvidia_render_manager_init: IN
INvmRenderManager::GetNvmRenderManager (&pRenderManager);
er = pRenderManager->Init(oConfig);
# Fpga header is not 0x4744482e (0xffffffff)!
App FPGA valid 0
Emergency FPGA valid 1
Disabling IOC watchdog
EmergencyApp-MMI3G: version 31.17.2098, date of build 08.09.2009
pRenderManager->Open()
nvidia_render_manager_init: OUT
discplayer_init: OUT
discplayer_init
discplayer_init: IN
dvdtrackplayer_init
discplayer_init: IN
dvdnavigator_init
created navigator control point with 8249288
mixer_init: IN
mixer_init: OUT
NvTRACELEVEL set to 3 (Level Info)
nVAudio_init: IN
nvidia_render_manager_init();
nVAudio_init: OUT
installing audio decoders
installing video decoders
nVAudio_init: IN
nVAudio_init: OUT
OnIpcGetCaptureUnitSourceCount
Number of displays: 6
Number of layers: 9
Graphics init was successfull: DisplaySize is 800x 480
Set DisplayStatus to 2
OnOff: process IPC event HWsample 209 HWvariant 178 FinalShutdown 0
SWDL: startUpdate HW index 209, variant 9478
OnOff: phase Scan metainfo
We have to erase orphaned headers
skipFile /HBpersistence/SWDL/Log/CfgAckRand.z 143
skipFile /HBpersistence/SWDL/Log/service/1/DirInfo.z 210
skipFile /HBpersistence/SWDL/Log/service/1/General.z 325
skipFile /HBpersistence/SWDL/Log/service/1/PreSWDL.z 714
skipFile /HBpersistence/SWDL/Log/service/1/PostSWDL.z 1349
skipFile /HBpersistence/SWDL/Log/service/2/DirInfo.z 2072
skipFile /HBpersistence/SWDL/Log/service/2/General.z 2187
skipFile /HBpersistence/SWDL/Log/service/2/PreSWDL.z 2576
skipFile /HBpersistence/SWDL/Log/service/2/PostSWDL.z 3204
skipFile /HBpersistence/SWDL/Log/service/2/Unusual.z 3977
skipFile /HBpersistence/SWDL/Log/SvmOld.z 4168
skipFile /HBpersistence/SWDL/history/DTCs/SVM/1/1970-01-01 00.01_Details.txt.z 4 571
skipFile /HBpersistence/SWDL/history/DTCs/SVM/2/1970-01-01 00.01_Details.txt.z 4 869
skipFile /HBpersistence/SWDL/history/DTCs/SVM/3/1970-01-01 00.01_Details.txt.z 5 220
skipFile /HBpersistence/SWDL/history/DTCs/SVM/4/1970-01-01 00.01_Details.txt.z 5 571
skipFile /HBpersistence/SWDL/history/DTCs/SVM/5/1970-01-01 00.02_Details.txt.z 5 669
skipFile /HBpersistence/SWDL/history/DTCs/SVM/6/1970-01-01 00.05_Details.txt.z 5 767
skipFile /HBpersistence/SWDL/history/DTCs/SVM/7/2011-11-13 00.05_Details.txt.z 5 865
skipFile /HBpersistence/SWDL/history/DTCs/SVM/8/2011-11-13 00.05_Details.txt.z 6 216
skipFile /HBpersistence/SWDL/history/DTCs/SVM/9/2011-11-13 00.07_Details.txt.z 6 314
skipFile /HBpersistence/SWDL/history/DTCs/SVM/10/2011-11-13 00.25_Details.txt.z 6412
skipFile /HBpersistence/SWDL/history/DTCs/SVM/11/2011-11-13 16.21_Details.txt.z 6511
skipFile /HBpersistence/SWDL/history/DTCs/SVM/12/2011-11-13 16.21_Details.txt.z 6610
skipFile /HBpersistence/SWDL/history/DTCs/SVM/13/2011-11-13 16.22_Details.txt.z 6709
skipFile /HBpersistence/SWDL/history/DTCs/SVM/14/2019-08-15 13.25_Details.txt.z 6808
skipFile /HBpersistence/SWDL/history/DTCs/SVM/15/2019-08-15 13.30_Details.txt.z 7162
skipFile /HBpersistence/SWDL/history/DTCs/SVM/16/2019-08-15 13.34_Details.txt.z 7514
skipFile /HBpersistence/SWDL/history/DTCs/SVM/17/2019-08-15 13.35_Details.txt.z 7613
skipFile /HBpersistence/SWDL/history/DTCs/SVM/18/2019-08-15 13.39_Details.txt.z 7712
skipFile /HBpersistence/SWDL/history/DTCs/SVM/19/2019-08-15 13.39_Details.txt.z 8064
skipFile /HBpersistence/SWDL/history/DTCs/SVM/20/2019-08-15 13.44_Details.txt.z 8163
skipFile /HBpersistence/SWDL/history/DTCs/SVM/21/2019-08-15 13.46_Details.txt.z 8514
skipFile /HBpersistence/SWDL/history/DTCs/SVM/22/2019-08-15 13.57_Details.txt.z 8866
skipFile /HBpersistence/SWDL/history/DTCs/SVM/23/2019-08-15 13.58_Details.txt.z 8965
skipFile /HBpersistence/SWDL/history/DTCs/SVM/24/2019-08-15 14.14_Details.txt.z 9064
skipFile /HBpersistence/SWDL/history/DTCs/SVM/25/2019-08-15 14.17_Details.txt.z 9415
skipFile /HBpersistence/SWDL/history/DTCs/SVM/26/2019-08-15 15.49_Details.txt.z 9514
skipFile /HBpersistence/SWDL/history/DTCs/SVM/27/2019-08-15 15.52_Details.txt.z 9866
skipFile /HBpersistence/SWDL/history/DTCs/SVM/28/2019-08-15 15.54_Details.txt.z 10218
skipFile /HBpersistence/SWDL/history/DTCs/SVM/29/2019-08-15 15.57_Details.txt.z 10571
skipFile /HBpersistence/SWDL/history/DTCs/SVM/30/2019-08-15 17.48_Details.txt.z 10923
skipFile /HBpersistence/SWDL/history/DTCs/SVM/31/2019-08-15 17.50_Details.txt.z 11276
skipFile /HBpersistence/SWDL/history/DTCs/SVM/32/2019-08-15 17.53_Details.txt.z 11629
skipFile /HBpersistence/SWDL/history/DTCs/SVM/33/2019-08-15 18.01_Details.txt.z 11982
skipFile /HBpersistence/SWDL/history/DTCs/SVM/34/2019-08-15 18.07_Details.txt.z 12335
skipFile /HBpersistence/SWDL/history/DTCs/SVM/35/2019-08-15 18.09_Details.txt.z 12686
skipFile /HBpersistence/SWDL/region.txt.z 12785
skipFile /HBpersistence/SWDL/FileCopyInfo/NaviPersistence.info 12847
skipFile /HBpersistence/SWDL/FileCopyInfo/MapStyles.info 13106
skipFile /HBpersistence/SWDL/FileCopyInfo/TMCConfig.info 13270
skipFile /HBpersistence/SWDL/FileCopyInfo/VW_ECE.info 13489
skipFile /HBpersistence/SWDL/update.txt.Abort.old 14011
skipFile /HBpersistence/FSC/00040401.fsc 19030
skipFile /HBpersistence/FSC/cache/00040400.fsc 19284
skipFile /HBpersistence/FSC/cache/00040401.fsc 19342
skipFile /HBpersistence/FSC/Logs/Security_Exceptions.log 19400
Set DisplayStatus to 4
fillInfoFromFpga: MU
scan for info: 0x40000: ff ff ff ff da ad da ad 40 53 57 44 4c 20 56 31
searchInfo 1
FPGA info header @SWDL V1@
FPGA info version 1
FPGA info variant 9478
FPGA info type Main Unit
FPGA info HW index 41
FPGA info region <noRegion>
FPGA info step 0
FPGA info HW index IT 0
FPGA info ignore region/variant 0
FPGA info loop 0
FPGA info repeat 0
FPGA info CRC e9207d49
SWDL: Stopping EFS driver!
Set DisplayStatus to 6
result of running command stop_efs_driver.sh is 0
SWDL: Starting EFS driver (automount)!
result of running command start_efs_driver.sh is 0
/HBpersistence/SWDL is available!
/HBpersistence/SWDL/update.txt doesn't exist
Don't use update.txt
SWDL: Mount from medium 3 (0)
OnOff: variant 9478
OnOff: DeviceName MU9478
Src: Medialauncher is running
Src: mount failed. Retry once in 1 s
Src: mount failed (medium unavailable 2)
SWDL: mount failed
SWDL: Mount from medium 4 (1)
SWDL: mount failed
SWDL: Mount from medium 5 (2)
SWDL: mount failed
SWDL: Mount from medium 2 (3)
Delay mount internal drive 0 1
Src: mount from CD ... still waiting...
Диск пока не вставлял, так как еще не записал, но не уверен, что поможет. Есть мысли как его правильно поднять?
VW Touareg RNS-850 USA
- Has thanked: 84 times
- Been thanked: 86 times
