Espace IV new card does not work properly
marcin2502
Been thanked: 1 time
Postby marcin2502 » 18 Nov 2017, 15:21
Hi, I got another batch of cards. Every time I add to espace IV I have the same problem. The card opens and closes the car no further than at the driver's side. In the picture I have read from EFfI and from what I see under the parameter sync I have 00 00 00 00 or so is it? Is it the reason that the cards do not work open and close? The seller claims that the card checks before shipment. I have an Eco tool with immo-tools.it so far the cards came from the same vendor and the problem was not and from about 20-30 made cards I have on most cars problems, few cars (mainly laguna) get rid of immediately
read with zed bull:
TRANSPONDER
E0 72 5A 39 SN/IDE
4D 49 4B 52 Crypto/isk Lo
FA EC 4F 4E Crypto/ISK Hi
06 AA 48 54 TMCF/PSW
00 00 00 00 USER 0
00 00 00 00 USER 1
00 00 00 00 USER 2
00 00 00 00 USER 3
REMOTE
4D 49 4B 52 RSK Lo
00 00 4F 4E RSK Hi
10 65 03 00 RCF
00 00 00 00 SYNC
I can not find the information under which pins connect PCFprog to do card reading
solitaire
Has thanked: 51 times
Been thanked: 189 times
Re: Espace IV new card does not work properly
Postby solitaire » 19 Nov 2017, 06:17
marcin2502
Postby marcin2502 » 19 Nov 2017, 21:03
After several attempts on several new cards I managed to draw the following conclusions:
- new programmed ecu tools launches but opens and closes at the glass, the cards program at 315 mHz and not 433 (so far i have ecu tool-s and card programmed without problem)
- way no. 2 - after connecting the ecu tools to the car after reading CRYPTO_LO and CRYPTO_HI i wrote the above values ​​with the zed bull mini edit the transponder with the values ​​shown by the ecu tools. After assigning the ecu tools card, the card was rewritten as a card with a frequency of 315mhz but the opening was working with a few meters.
Maybe someone has an idea why this ecu tool-s is not coping with it, and it has to be edited transponder (so far I had the same card) and the transponder did not have to move and program the new card itself ecu tool-s enough.
Users browsing this forum: sereja_1962f and 38 guests
