ISN extract DDE4
AFR
ISN extract DDE4
Postby AFR » 09 Mar 2017, 11:13
Hi Folks,
I'm having problems to extract ISN from this eeprom. I hope anyone would be able to help. The file should be fine compared with other eep from DDE4.
File is attached. From an E46 330d.
Many thanks in advance!
Andreas, Sweden.
anton
Has thanked: 223 times
Been thanked: 56 times
Re: ISN extract DDE4
Postby anton » 09 Mar 2017, 14:32
ISN:33DC.ROLLING1:647D199C.ROLLING2:1AE22123
AFR
Postby AFR » 09 Mar 2017, 14:38
Thanks man! Also got same by PM so this will probably work :)
Rgds//A
zorik
Postby zorik » 26 Mar 2017, 11:31
If necessary I can make a pure isn with the laying of your eeprom, put it in the block and make synchronization. I can remove isn from the dump eeprom dde4 dde5
Users browsing this forum: Google [Bot] and 19 guests
