WV t5 coding
- Poma
- Has thanked: 9 times
- Been thanked: 184 times
WV t5 coding
Нужна инфа по длинному кодированию по всем блокам.
- Poma
Re: WV t5 coding
2010-2014
Re: WV t5 coding
Pama, ты пиши чо за проблема, а то не очень ясно чо тебе надо.
лог от caravelle 2013 Европа:
Chassis Type: 6N0
Scan: 01 02 03 08 09 10 15 17 18 19 25 37 56 69
VIN: WV2ZZZ7HZDH107337
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (J623-CCHA) Labels: None
Part No SW: 03L 906 019 FL HW: 03L 907 309 M
Component: R4 2,0L EDC H45 5582
Revision: 26H45--- Serial number: 00000000000000
Coding: 0125401A233400080000
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019FL 003003
ROD: EV_ECM20TDI01103L906019FL.rod
VCID: 7AF1991DFD3AF4C86F8
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BT 300 045 P HW: 0BH 927 711 C
Component: DSG DQ500-7F H07 1801
Revision: 00H07V01
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_VN75.rod
VCID: 428121FDD56A7C08778
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 208724AD09A4049C24A390726A6610
Shop #: WSC 02756 790 49152
VCID: 3A71591DB5BA34C82F8
Address 08: Auto HVAC (J255) Labels: 7E5-907-040.clb
Part No SW: 7E5 907 040 S HW: 7E5 907 040 S
Component: ClimatronicT5 H18 0406
Revision: 00001000
Coding: 0000000103
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimatronicT5.rod
VCID: 3875431583B626D8D9C
1 Fault Found:
9480753 - Control/Display Unit for Rear Climatronic
B10AA 31 [009] - No Signal
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 31
Reset counter: 44
Mileage: 4185 km
Date: 2001.14.31
Time: 00:17:20
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 K HW: 7H0 937 087
Component: BCM T5GP H+4 H32 0407
Revision: BO032001 Serial number: 0533 054130050
Coding: E8B079380A212212002808102C2B8DD40080410F60840000320000000000
Shop #: WSC 02756 790 12345
VCID: 3C7D5F05BF8E0AF83D4
Subsystem 1 - Part No SW: 7E0 959 801 HW: 7E0 959 801
Component: J386__TSG_FT 002 3313
Coding: 000000
Subsystem 2 - Part No SW: 7E0 959 802 HW: 7E0 959 802
Component: J387__TSG_BT 002 3313
Coding: 000000
1 Fault Found:
00329 - Control Circuit for Unlocking Rear Lid
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 44
Mileage: 4609 km
Time Indication: 0
Date: 2002.14.09
Time: 13:43:47
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28261301900507
Coding: 310104
ASAM Dataset: EV_VW75XParkAssis8K 001003
ROD: EV_VW75XParkAssis8K.rod
VCID: 3B7F5C19B2800DC034E
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag003 H07 0013
Revision: -------- Serial number: 003HL00GCKUX
Coding: 000000000000000000000000000000003033
Shop #: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750_VN75.rod
VCID: 356B4A2194A4DBB0C2A
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 7E0 920 870 G HW: 7E0 920 870 G
Component: KOMBI H06 0605
Coding: 160E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_VN75.rod
VCID: 2D5B62417CF49370BAA
2 Faults Found:
9453330 - Outside temperature sensor
B103F 1B [008] - Resistance Too High
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [137] - General checksum failure
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 C
Component: J737__Standheizung 0605
Revision: 00087000 Serial number: 09024900A00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 254B9A61EC04AB3072A
1 Fault Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 9
Mileage: 4392 km
Time Indication: 0
Date: 2002.14.03
Time: 10:59:32
Freeze Frame:
OFF
Temperature: 59.0°C
Voltage: 14.08 V
Temperature: 3.5°C
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H32 0407
Revision: BO032001
Coding: 042200
VCID: F0E53B3523463E9851C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H06 0605
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VN75.rod
VCID: EAD1295D0D9AC4481F8
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H10 5238
Revision: AB001001 Serial number: VWZ6Z7N7066131
Coding: 0A010400040000810014
Shop #: WSC 01357 011 00200
ASAM Dataset: ------------------------- ------
VCID: 3B7F5C19BA800DC034E
Subsystem 1 - Part No: 1T0 919 859 C
Component: EU East V10 8009
5 Faults Found:
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 230
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
00859 - Line-Output; Front Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
00823 - Line-Output; Front Left
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
00869 - Line Output; Rear Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
00860 - Line-Output; Rear Left
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Anhaenger H10 0110
Revision: 3B001001 Serial number: 00000192884450
Coding: 410D000101000000
Shop #: WSC 02756 790 00000
VCID: 31637E3168CCF7909E2
1 Fault Found:
00532 - Supply Voltage B+
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 3659 km
Time Indication: 0
Date: 2001.14.26
Time: 03:03:21
End ---------------------------------------------------------------------
Chassis Type: 6N0
Revision: 00H07V01
Coding: 0014
Revision: 00H43001
Revision: 00001000
Coding: 0000000103
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 31
Reset counter: 44
Mileage: 4185 km
Date: 2001.14.31
Time: 00:17:20
Coding: 000000
Coding: 000000
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 44
Mileage: 4609 km
Time Indication: 0
Date: 2002.14.09
Time: 13:43:47
Coding: 310104
Coding: 160E01
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Coding: 0000031
1 Fault Found:
00664 - Fuel gauge
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Mileage: 4392 km
Time Indication: 0
Date: 2002.14.03
Time: 10:59:32
Freeze Frame:
OFF
Temperature: 59.0°C
Voltage: 14.08 V
Temperature: 3.5°C
Revision: BO032001
Coding: 042200
Serial number:
Coding: 000000
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 63
Reset counter: 44
Mileage: 4192 km
Time Indication: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 28
Mileage: 3659 km
Time Indication: 0
Date: 2001.14.26
Time: 03:03:21
- Poma
Re: WV t5 coding
Я ПРО ЭТО
VEHICLE DIAGNOSTIC REPORT
Long Coding(30 Byte)
00 08 00 00 00 00 00 00 00 98 02 80 54 00 29 74 23 D5 00 88 60 6C 8F 60 E4 80 40 24 00 40
Byte 00: Hex = 00 Binary = 00000000
Only Limited Coding Information is available for this Control Module.
Coding is normally done using the Factory Tool and Software-Version-Management (SVM).
The Bytes 00 - 08 & 10 are not in use (always 00)!
Byte 09: Hex = 98 Binary = 10011000
V Bit 3 Multi-Function-Display/Board Computer via Operation and Display Protocol (BAP) active
V Bit 4 Personalization via Key inactive
Byte 11: Hex = 80 Binary = 10000000
X Bit 2 Permanent Running Light (PRL) via Low Beam active
X Bit 5
V Bit 7 Parking Lights with Terminal 15/Ignition OFF only w/o direct Change from Turn Signal to Parking Light
Byte 12: Hex = 54 Binary = 01010100
X Bit 0 Coming-Home Timer (0 = Start with Term.15 OFF / 1 = Start with Door Opening)
V Bit 2 Coming-Home Mode (0 = automatic / 1 = manual)
V Bit 4 Cornering Light Activation Time limited
X Bit 5 Footwell Lights with Terminal 58d active
V Bit 6 Window Washer Heating via Left Side Turning Light Output
X Bit 7
Byte 14: Hex = 29 Binary = 00101001
V Bit 0 Front Fog Lights installed
X Bit 1 Daytime Running Lights (DRL) via Fog Lights active
X Bit 2 Fog Lights inactive with High Beams active
V Bit 3 Bi-Xenon Headlights (with Shutter) installed
X Bit 7 Cornering Lights via Front Fog Lights active
Byte 15: Hex = 74 Binary = 01110100
X Bit 0 High Beams inactive with Rear Fog Light(s) active
V Bit 2 Rear Fog Lights inactive while Trailer attached
X Bit 3 Daytime Running Lights (DRLs) inactive with Turn Signals active
V Bit 4 Deactivation for Brake Light via Tail Light with Fog Lights ON
V Bit 5 Parking Lights OFF with Terminal S OFF and Light Switch at Low Beam
V Bit 6 Daytime Running Light (DRL) via separate Lights active
X Bit 7 Daytime Running Light (DRL) Adaptation active (MFA+)
Byte 16: Hex = 23 Binary = 00100011
V Bit 0 Comfort Blinking (Highway Blinking) active
V Bit 1 Emergency Brake Flashing via Brake Lights active
X Bit 2 Emergency Brake Flashing via Turn Signals active
X Bit 6 Brake Lights w/o Terminal 15/Ignition ON active
Byte 17: Hex = D5 Binary = 11010101
V Bit 0 Adaptive Light/Cornering Light Variant (0 = Cornering Light / 1 = Adaptive Light)
X Bit 3 Coming-Home (CH) via Fog-Lights active
V Bit 4 Assistace Driving Light (ADL) active
X Bit 5 Coming-Home (CH) active
V Bit 6 Leaving-Home (LH) active
V Bit 7 License Plate Light w/o Pulse Width Modulation (PWM) [LED Light]
Byte 18: Hex = 00 Binary = 00000000
V Bit 0-7,00 Light Setup: Standard/Parameter Settings (EEPROM)
1
Byte 19: Hex = 88 Binary = 10001000
X Bit 0-3,00 Headlight Dimming (Life Time Extension) inactive
X Bit 0-3,01 Headlight Dimming (Life Time Extension): 12.3 V
X Bit 0-3,02 Headlight Dimming (Life Time Extension): 12.4 V
X Bit 0-3,03 Headlight Dimming (Life Time Extension): 12.5 V
X Bit 0-3,04 Headlight Dimming (Life Time Extension): 12.6 V
X Bit 0-3,05 Headlight Dimming (Life Time Extension): 12.7 V
X Bit 0-3,06 Headlight Dimming (Life Time Extension): 12.8 V
X Bit 0-3,07 Headlight Dimming (Life Time Extension): 12.9 V
V Bit 0-3,08 Headlight Dimming (Life Time Extension): 13.0 V
X Bit 0-3,09 Headlight Dimming (Life Time Extension): 13.1 V
X Bit 0-3,0A Headlight Dimming (Life Time Extension): 13.2 V
X Bit 0-3,0B Headlight Dimming (Life Time Extension): 13.3 V
X Bit 0-3,0C Headlight Dimming (Life Time Extension): 13.4 V
X Bit 0-3,0D Headlight Dimming (Life Time Extension): 13.5 V
X Bit 0-3,0E Headlight Dimming (Life Time Extension): 13.6 V
X Bit 0-3,0F Headlight Dimming (Life Time Extension) via Fixed Value/EEPROM
X Bit 4-7,00 Tail Light Dimming (Life Time Extension) inactive
X Bit 4-7,10 Tail Light Dimming (Life Time Extension): 12.3 V
X Bit 4-7,20 Tail Light Dimming (Life Time Extension): 12.4 V
X Bit 4-7,30 Tail Light Dimming (Life Time Extension): 12.5 V
X Bit 4-7,40 Tail Light Dimming (Life Time Extension): 12.6 V
X Bit 4-7,50 Tail Light Dimming (Life Time Extension): 12.7 V
X Bit 4-7,60 Tail Light Dimming (Life Time Extension): 12.8 V
X Bit 4-7,70 Tail Light Dimming (Life Time Extension): 12.9 V
V Bit 4-7,80 Tail Light Dimming (Life Time Extension): 13.0 V
X Bit 4-7,90 Tail Light Dimming (Life Time Extension): 13.1 V
X Bit 4-7,A0 Tail Light Dimming (Life Time Extension): 13.2 V
X Bit 4-7,B0 Tail Light Dimming (Life Time Extension): 13.3 V
X Bit 4-7,C0 Tail Light Dimming (Life Time Extension): 13.4 V
X Bit 4-7,D0 Tail Light Dimming (Life Time Extension): 13.5 V
X Bit 4-7,E0 Tail Light Dimming (Life Time Extension): 13.6 V
X Bit 4-7,F0 Tail Light Dimming (Life Time Extension) via Fixed Value/EEPROM
Byte 20: Hex = 60 Binary = 01100000
X Bit 0 Footwell Lights installed
X Bit 1 Interior Light Activation via Rear Lid Latch
X Bit 4 Interlock Display (Press Clutch) in Instrument Cluster active
V Bit 5 Headlight Washer installed
V Bit 6 Interior Light Dimming via Body Control Module (BCM)
Byte 21: Hex = 6C Binary = 01101100
X Bit 0 Rear Wiper installed
V Bit 2 Automatic Rear Window Wiping with Front Wiper at Interval active
V Bit 3 Automatic Rear Window Wiping with Front Wiper at Permanent active
X Bit 4 Tear Drop Wiping for Rear Wiper active
V Bit 5 Rain/Light Sensor (RLS) installed
V Bit 6 Automatic Rear Window Wiping with Reverse Gear active
Byte 22: Hex = 8F Binary = 10001111
V Bit 0 Heated Rear Window installed
V Bit 2 Seat Heating installed
V Bit 3 Electronic Fuel Pump Relay (EFP) installed
X Bit 6 Common Electronic Fuel Pump Relay (EFP) with Engine Control Unit (ECU)
V Bit 7 Air Conditioning/Climate Control installed
Byte 23: Hex = 60 Binary = 01100000
X Bit 0 Monitoring: Plausibility Terminal 50 HW/CAN
X Bit 1 Monitoring: Feedback Terminal 50
X Bit 3 Relay 75/X OFF
V Bit 5 Load Management active
V Bit 6 Lamp Monitoring (Cold) License Plate Lamps active
Byte 24: Hex = E4 Binary = 11100100
Bit 0-6,1 Daytime Running Light (DRL) Dimming
Bit 0-6,1 Decimal Value (Resolution: 1 %)
V Bit 7 Daytime Running Lights (DRLs) as Position Lights active
Byte 25: Hex = 80 Binary = 10000000
X Bit 3 Monitoring: Footwell Lights inactive (LED Footwell Lights)
X Bit 6 Headlight Washer with Daytime Running Light (DRL) active
V Bit 7 Quiescent Voltage active with Transport Mode (TRA) active
2
Byte 26: Hex = 40 Binary = 01000000
X Bit 0 External Start/Stopp Information active
X Bit 1 Generator connected via LIN Data Bus
X Bit 2 Recuperation active/installed
X Bit 3 Daytime Running Light (DRL) only active with Assistance Driving Light (ADL) active
V Bit 6 Enabling Cornering Light with Reverse Gear active
X Bit 7 Enabling Start/Stopp Function
Byte 27: Hex = 24 Binary = 00100100
V Bit 2 LED-Daytime Running Light (DRL) Module for Parking/Position Light && Daytime Running Light (DRL)
V Bit 5 Emergency Brake Flashing active with Trailer attached
X Bit 6 Secondary Brake Light Deactivation active
X Bit 7 Rear Wiper Continuous Rotation active
Byte 29: Hex = 40 Binary = 01000000
X Bit 0 External Energy Management/Battery Data Module installed
V Bit 6 Momentary Switch for High Beam
3
Вытягивается это у хз какого софта по адресу:
Path: Diagnosis\Control Unit\09-Cent. Elect.\Coding\Software Coding:00 08 00 00 00 00 00 00 00 98 02 80 54 00 29 74 23 D5 00 88 60 6C 8F 60 E4 80 40 24 00 40 \
VIN: WVWZZZ3CZDP010061
X Bit 5
X Bit 7
1
2
3
