Peugeot 307 2003
hackbest
Has thanked: 2 times
Been thanked: 1 time
Peugeot 307 2003
Postby hackbest » 05 Feb 2014, 17:02
Howdy partner need to vary bsi 120000 Someone I can lend a hand thanks and greetings
Peugeot 307 2003
Re: Peugeot 307 2003
Postby Ashot2009 » 05 Feb 2014, 17:40
Какой пробег в Вашем дампе ?
Что показывает приборка (думаю 999999)?
hackbest
Postby hackbest » 05 Feb 2014, 22:56
here have already bsi file modificaco 120000km but there is a trick but I can not get to save again this puts the original in tachosoft
Instruction: read the 68HC912DG128 chip from the BSI (Valeo), and
edit the mileage as shown here. Then connect dash to the connectors .
on the car WITHOUT the BSI. Put the key to the ignition, but do not start!!!
just power on the dash. Dash value will self deletes.
After this connect the BSI and km value will be automatically loaded from BSI to dash.
I do not get that record
someone can help me thanks
Postby Ashot2009 » 06 Feb 2014, 08:53
Нужно делать и приборку
hackbest
Postby hackbest » 06 Feb 2014, 09:24
Hello again anyone know how to reset the dash or trick to record the miles of bsi records in this case but alos removing contact returning originals.
Postby Daniulis » 06 Feb 2014, 11:51
Если сипмтом, разговор чисто с собой (в одни ворота), как поставить диагноз?
Return to “Dashboards”
