Key Cadillac
Vodik
Has thanked: 76 times
Been thanked: 64 times
Key Cadillac
Postby Vodik » 10 Dec 2013, 14:21
Приветствую.
Привезли прописать ключик на Кадиллак CTS 2007 года. Новый смарт-ключ не видит ни Танго, ни Абритус . Внутри PCF7952. Родной ключ нормально читается - но как-то подозрительно - читаются ВСЕ страницы с дефаултной криптой ( 4D 49 ...). Так и должно быть ?
Vodik
Re: Key Cadillac
Postby Vodik » 12 Feb 2014, 16:09
Мож кто знает, или есть мануал как прописать новый ключ ? Пробую Key Fob Program - не хочет. Может сначала надо ключ к иммо обучить ?
Re: Key Cadillac
Postby RADEON » 12 Feb 2014, 20:28
Antitheft and Alarm Systems: Service and Repair
Adding Keys (Domestic)
ADDING KEYS (DOMESTIC)
IMPORTANT:
- To initiate, this procedures requires that a learned master key be available.
- A total of 10 master keys or valet keys may be programmed to a single vehicle.
- This procedure adds keys only. The procedure does not erase previously learned keys.
- The keys to be learned must duplicate the mechanical cut of the current key.
- If more than one valet key is to be learned, immediately precede each valet key with a learned master key.
1. With a previously learned master key, turn ON the ignition, with the engine OFF.
2. Turn OFF the ignition and remove the key.
3. Within 10 seconds insert the key to be learned. Turn ON the ignition with the engine OFF. The vehicle has now learned the new key.
Re: Key Cadillac
Postby RADEON » 12 Feb 2014, 20:29
Adding Keys (Export including Canada)
ADDING KEYS (EXPORT INCLUDING CANADA)
IMPORTANT:
- You may add up to 10 additional master keys or valet keys using this procedure if 2 learned master keys are available. If 2 learned master
keys are not available the 10 minute relearn procedure must be performed. Refer to Programming Theft Deterrent System Components.
- If more than one valet key is to be learned, immediately precede each valet key by 2 learned master keys.
1. With a previously learned master key, turn ON the ignition with the engine OFF.
3. Within 10 seconds insert a second previously learned master key. Turn ON the ignition with the engine OFF.
4. Turn OFF the ignition and remove the key.
5. Within 10 seconds insert the key to be learned. Turn ON the ignition with the engine OFF. The vehicle has now learned the new key.
Vodik
Re: Key Cadillac
Postby Vodik » 13 Feb 2014, 09:17
Спасибо.
Но речь про смарт ключ. Вставлять не куда. Вернее в подлокотнике есть слот для ключа, но процедура Key Fob Program заканчивается ошибкой - Key Not Detected.
puz1
Been thanked: 1 time
Re: Key Cadillac
Postby puz1 » 15 Feb 2014, 08:45
вот с автодаты
Users browsing this forum: autolocksman and 45 guests
