w211 EIS Help!
Re: w211 EIS Help!
efka wrote:Unfuckingbelieveble but..... its like I got 722.7 first gear cluch set. same part number diff. stuff inside. What are the masks of both procers? I will check connections for both in the morning at work. Did you get new eis? Do you have anything to write keys with?
And..... when you get new eis (iff you do) don't forget not to return orange key it MB but to send to us for testing. We need it more than Mercedes!!!!!
Re: w211 EIS Help!
No I cant write keys (I thought i could but ms china screwed me) mask of the e500 hc12 is 3K91D. I dont know what the mask of the st12 e320? it did not match so I did not bother taking it apart. New eis should be here tommorow. Thanks again!!
Re: w211 EIS Help!
ENIGMA wrote:No I cant write keys (I thought i could but ms china screwed me) !!
you are srewing yourself with China.
Re: w211 EIS Help!
Ok an update the owner just got the car registration is not in his name dealer won't sell the lock to him for another month. So can someone give me the eis part # that might carry the same lock (I can't find my part # anywhere near by) 211 545 10 08 w211 hc12
Re: w211 EIS Help!
And what you gonna do with it? You have nothing to write key with!!!!! Its either leave it for somebody else, buy yourself a set from junkyard (it costs nothing at car-part.com) or start using decent tools for that purpse. Still you did not answer what was your initial task on that car?
Re: w211 EIS Help!
Hi all so I got the car started !
one of the pins on the mcu did not get soldered down all the way after my removal, a friend stopped by and noticed it. I also found a flash with the same part number and installed that so not too sure what the problem was the mcu or the flash? But pretty sure it was the mcu. Thanks for the help everyone!!
one of the pins on the mcu did not get soldered down all the way after my removal, a friend stopped by and noticed it. I also found a flash with the same part number and installed that so not too sure what the problem was the mcu or the flash? But pretty sure it was the mcu. Thanks for the help everyone!!- Daniulis
Re: w211 EIS Help!
I'd give a medal to yours customer, he's very patient. Also you've got a good practice, hope it will be a good lesson for the future.
