PCFprog
skematix
Re: PCFprog
the following do not work:
chrysler all except m3m
gm (buick/chev/gmc)
nissan
all available connection diagram do not help wether used as is or reversed. the chips do not read at all.
gm (buick/chev/gmc)
nissan
wormland
Re: PCFprog
Hi,
I am trying to reprogram Volvo keys. With the 6 button key there is no problem. But with the 5 button key I can not connect. Anybody knows why?
I have tried many keys....
Best regards,
Fredrik
Best regards,
Fredrik
- Been thanked: 1929 times
Re: PCFprog
Nobody knows....
Tons of Chrysler, Nissan and Volvo 5-button keys are done without any problems.
But! Always there is somebody having problems to attach 4 wires correctly.
Another team of experts are just trying to reset Megamos based keys or 7946/47 hardware based transponders...
As a common rule, these people aren't posting any pictures of their exploits...
Re: PCFprog
Hi everyone.
I bought the pcf prog a week ago.now have some time to try it.
I have some Opel keys 7941.im am trying to read but always get "boot fail".
I don't know if I have to make any adjustments in the software.i just selected 41/61 in boot.
All the other settings as it came.connections are good 100%.
Anny suggestions ?
Thanks
Anny suggestions ?
Thanks
Re: PCFprog
Ok,now I soldered wires..I am using MK3 wiring diagram.any advice? thanks
Re: PCFprog
Comizelu wrote:Ok,now I soldered wires..I am using MK3 wiring diagram.any advice? thanks![]()
swap yellow and green...
Re: PCFprog
Same result
Re: PCFprog
It works now..
I swapped SDA & SCL and had the same result..found the my vvdi2 was the problem.when using vvdi2 and pcf prog attached both to same computer,pcf prog not working..
Thanks for assistance.
- solitaire
- Has thanked: 51 times
- Been thanked: 189 times
Re: PCFprog
может кто-то видел даташеет на етот камень F2951E? стоит в новых GM ключах.. ищу где у него SDA, SCL
skematix
Re: PCFprog
Girts wrote:Nobody knows....
Common rule they can't show a picture of a circuit board because they still need to provide the eep or erom lol. what a story you create to cover up the fact most keys other programmers can do are not supported by pcfprog.
Re: PCFprog
Ohh, yes, yes!
Tool not working? May be it isn't working only for you and problem really is not a tool?
In addition, we aren't selling brain, knowledge and soldering skills.
So... no pictures from you, no exact key numbers and types, no any descriptions about settings used. What do you wish from support?
Anybody knows that any question must contain 3/4 of correct answer, otherwise answer is impossible.
Anyway, thanks for your opinion and feedback.
Re: PCFprog
solitaire wrote:может кто-то видел даташеет на етот камень F2951E? стоит в новых GM ключах.. ищу где у него SDA, SCL
нужно ещё?
- solitaire
Re: PCFprog
Kinder wrote:solitaire wrote:может кто-то видел даташеет на етот камень F2951E? стоит в новых GM ключах.. ищу где у него SDA, SCL
нужно ещё?
да
- antuk
- Has thanked: 174 times
- Been thanked: 123 times
Re: PCFprog
Товарищи , хелп ми плиз
Как его подключить?
BMW new key
Как его подключить?
BMW new key
Re: PCFprog
Так неподходит?
- jevgensolo
- Has thanked: 841 times
- Been thanked: 738 times
Re: PCFprog
Как-то так...
