AVL
Postby AVL » 03 Sep 2013, 15:55
Пока нет у меня Каналайзера, подцепился к драйверу КАН Saleae Logic.
Code: Select all
0.48984025,92,DATA,'442' (0x1BA),'5' (0x5),'255' (0xFF) " (0x22) '192' (0xC0) d (0x64) ! (0x21),'31490' (0x7B02),ACK
0.4921129375,93,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
0.5021311875,94,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
0.505031625,95,DATA,'1894' (0x766),'8' (0x8),'0' (0x00) '20' (0x14) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00),'10393' (0x2899),ACK
0.5088565,96,DATA,'442' (0x1BA),'5' (0x5),'255' (0xFF) " (0x22) '192' (0xC0) d (0x64) ! (0x21),'31490' (0x7B02),ACK
0.512105375,97,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
0.52136225,98,DATA,'902' (0x386),'6' (0x6),'2' (0x02) '189' (0xBD) '146' (0x92) t (0x74) E (0x45) '0' (0x00),'2937' (0x0B79),ACK
0.5221624375,99,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
0.52894,100,DATA,'442' (0x1BA),'5' (0x5),'255' (0xFF) " (0x22) '192' (0xC0) d (0x64) ! (0x21),'31490' (0x7B02),ACK
0.5323729375,101,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
0.5328293125,102,DATA,'1914' (0x77A),'8' (0x8),'255' (0xFF) '0' (0x00) '150' (0x96) '4' (0x04) '220' (0xDC) '254' (0xFE) @ (0x40) '255' (0xFF),'14709' (0x3975),ACK
0.5334736875,103,DATA,'1178' (0x49A),'7' (0x7),'0' (0x00) Q (0x51) h (0x68) : (0x3A) a (0x61) 7 (0x37) D (0x44),'4889' (0x1319),ACK
0.542131625,104,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
0.5486451875,105,DATA,'442' (0x1BA),'5' (0x5),'255' (0xFF) " (0x22) '192' (0xC0) d (0x64) ! (0x21),'31490' (0x7B02),ACK
0.5529183125,106,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
0.562160375,107,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
0.5687779375,108,DATA,'442' (0x1BA),'5' (0x5),'255' (0xFF) " (0x22) '192' (0xC0) d (0x64) ! (0x21),'31490' (0x7B02),ACK
0.572122875,109,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
0.582133125,110,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
0.6221533125,117,DATA,'250' (0x0FA),'7' (0x7),'0' (0x00) '0' (0x00) " (0x22) '0' (0x00) '0' (0x00) '0' (0x00) '2' (0x02),'16950' (0x4236),ACK
Что мне в нём нравится, что чётко видно время события.
В Каналайзере тоже можно так разложить по времени?
Спасибо!
AVL
Postby AVL » 03 Sep 2013, 16:20
Что значит NAC в посылке?
Code: Select all
Time [s],    Packet,Type,Identifier,                                         Control,Data,        CRC,       ACK
0.0004021875,0,DATA,'1894' (0x766),'8' (0x8),'0' (0x00) '16' (0x10) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00),'31343' (0x7A6F),NAK
0.0009501875,1,DATA,'1894' (0x766),'8' (0x8),'0' (0x00) '16' (0x10) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00),'31343' (0x7A6F),NAK
0.00149825,2,DATA,'1894' (0x766),'8' (0x8),'0' (0x00) '16' (0x10) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00) '0' (0x00),'31343' (0x7A6F),NAK
Сам себе и отвечаю:
NAK, 15 — Negative Acknowledgment, не подтверждаю. Обратно Acknowledgment.
Vasily
Has thanked: 224 times
Been thanked: 494 times
Postby Vasily » 03 Sep 2013, 17:49
FunCar wrote:Шина K-CAN бмв (100).
Порт1 (LH) подключен к шине авто, порт 2 одним проводом к ЭБУ (без разницы какой L или H) - моргают светодиоды RX1 TX1 и RX2 TX2. Все арбайтен, общение есть в обе стороны.
Почему может быть такая проблема?? Я еще понаблюдаю, может чего упустил, но вроде уже все проверено. Эбу рабочий, на шине висячих блоков нет.
Это по тому что нужно внимательно смотреть куда вы цепляетесь, вы прицепились на комфорт шину, так? что с терминаторами на сканере, отключены?
Vasily
Postby Vasily » 03 Sep 2013, 17:52
AVL wrote:Пока нет у меня Каналайзера, подцепился к драйверу КАН Saleae Logic.
Спасибо!
Какой ужос.
А вы что в каналайзере не видите время? или в канарейке при приеме пакетов?
FunCar
Postby FunCar » 03 Sep 2013, 19:35
Vasily wrote:Это по тому что нужно внимательно смотреть куда вы цепляетесь, вы прицепились на комфорт шину, так? что с терминаторами на сканере, отключены?
Отключены
Vasily
Postby Vasily » 03 Sep 2013, 21:43
Значит только по одному проводу, потому что кан сканер имеет драйвера HS а у вас шина FT.
AVL
Postby AVL » 04 Sep 2013, 13:10
Спасибо!
Какой ужос.
Вот лог Каналайзера.
Code: Select all
0FA, 00, 7, 00 00 22 00 00 00 02
766, 00, 8, 00 14 00 00 00 00 00 00
386, 00, 6, 02 94 D5 AF FC 00
1BA, 00, 5, FF 22 C0 64 21
77A, 00, 8, FF 00 96 04 DC FE 40 FF
49A, 00, 7, 00 33 D3 66 CE 64 FA
Ну не вижу я ТУТ время или где его смотреть?
Vasily
Postby Vasily » 04 Sep 2013, 17:33
AVL
Postby AVL » 05 Sep 2013, 16:52
Не вижу я на этих скринах, где отображается время события, то-есть какая посылка за какой пошла.
Или мы с Вами говорим о разном понятии ВРЕМЯ.
Вот тут в логе конкретно видна последовательность посылок:
0.5687779375,
0.572122875,
0.582133125,
Я ЭТО время имел ввиду, а Вы про какое?
Vasily
Postby Vasily » 05 Sep 2013, 18:20
Так и я об этом, вам надпись TIME ничего не говорит? у вас время в чем, в сек? и какая разница какая посылка за какой пошла? кстати в каналайзере и канари это видно.
Vasily
Postby Vasily » 05 Sep 2013, 19:28
И еще версия Канари у вас какая? а то лог который выложили коротковат как-то.
AVL
Postby AVL » 06 Sep 2013, 06:14
Vasily wrote:Так и я об этом, вам надпись TIME ничего не говорит? у вас время в чем, в сек? и какая разница какая посылка за какой пошла? кстати в каналайзере и канари это видно.
У меня два устройства в сети.
Время в секундах.
Логическим анализатором я становлюсь на два ТХ и один РХ. Этого мне достаточно, что мониторить все процессы.
Соответственно время начала процесса мне важно, так-как по нему я вижу очерудность посылок в системе.
AVL
Postby AVL » 06 Sep 2013, 06:26
Vasily wrote:И еще версия Канари у вас какая? а то лог который выложили коротковат как-то.
Это лог не с Канари.
Мой Фордометр пока отправлен в ремонт, по-этому, извините пожалуйста, что пока-что в в этом топике даю лог не с Вашего устройства.
AVL
Postby AVL » 06 Sep 2013, 06:30
Зелёным оваликом обведён импульс подтверждения приёма посылки?
А если эту посылку примут 5 различных блоков?
То и импульсов будет пять? Или сколько?
Как передающий блок узнает, что именно все 5 нужных устройств приняли переданную для них информацию?
Спасибо!
AVL
Postby AVL » 17 Sep 2013, 08:51
Фордометер как КАН-фильт работать не будет?
slalex
Postby slalex » 17 Sep 2013, 11:35
AVL wrote:Как передающий блок узнает, что именно все 5 нужных устройств приняли переданную для них информацию?
Спасибо!
на сколько я понял принцип работы КАН шины, то считается, если один из блоков принял посылку, то и другие ее тоже приняли.
Vasily
Postby Vasily » 17 Sep 2013, 13:06
AVL wrote:Фордометер как КАН-фильт работать не будет?
1й будет, 2й нет.
Vasily
Postby Vasily » 17 Sep 2013, 13:07
slalex wrote:на сколько я понял принцип работы КАН шины, то считается, если один из блоков принял посылку, то и другие ее тоже приняли.
Совершенно верно. Вернее ее все принимают.
djal
Been thanked: 4 times
Postby djal » 17 Sep 2013, 17:32
сканер еще не получил но вопрос уже есть
можно ли работать с AU5790
Single wire CAN transceiver (однопроводной)
Vasily
Postby Vasily » 18 Sep 2013, 08:25
djal wrote:можно ли работать с AU5790
Можно.
