SAAB SCL EMULATOR PROBLEM
LuceK17
hi i can't program the emulaotr to SAAB. Every time "erorr no response". I tried bench supply on table and OBD power supply in the car. No effects. The LEDs do not blink and do not light up after applying power. Please help.
Re: SAAB SCL EMULATOR PROBLEM
No led = no power.
Check your setup.
Check your setup.
LuceK17
I checked many times. I checked the power supply on the 10Y47A chip, there is 5V and ground but the LED are still off.
LuceK17 wrote:I checked many times. I checked the power supply on the 10Y47A chip, there is 5V and ground but the LED are still off.
Sounds like you simply killed it...
LuceK17
How could I do that? if I followed the manual. Before the first time, I checked everything several times and the first time the LED was off. It looks like I bought it damaged.
kesik
- Has thanked: 5 times
- Been thanked: 12 times
LuceK17 wrote:How could I do that? if I followed the manual. Before the first time, I checked everything several times and the first time the LED was off. It looks like I bought it damaged.
all emulators are tested before shipping .
we don't know whats it's wrong with your emulator .
maybe you made some short circuit inadvertently ?
what kind of K-line adapter you use ?
what kind of WIN. do you use ?
meyby you really kill it yours emulator...
LuceK17
I was very careful. I checked everything many times so I don't think it could be a short circuit.
First time Windows 7 32bit without internet connection and then win 10 with internet.
Kline adpater is simply kkl for vag, works fine all the time.
I would like to know if I did wrong because I don't want to kill the next emulator.
Who knows....
for example 220v on soldering iron tip can kill almost everything.
Make a pic of your connection and post here.
BWF
I have the same problem, the emulator does not turn on any led and the connections are all good, no short circuit has been made.
It seems that the connection scheme is bad, or some emulators are in bad condition
"no response" or "no echo"?
if 2nd - problem is at your side 100%, wrong hardware used or not used at all.
if 1st - may be anything. To solve: 90% - must read manual once again, 10% - must check your hardware.
No screens and no problem description = no help possible.
What's about 3rd option - Yourself?
Just idea, nothing private...
BWF wrote:It seems that the connection scheme is bad, or some emulators are in bad condition
ucmelectronics
- Has thanked: 1 time
Hello, good afternoon, I have a problem and I didn't know that I had to ask for a Kline programmer for this. Can the memory be programmed by ICP? With vvdi prog or something. If someone has to prepare the file and pay you, I have no problem with it, I need to solve it and the messaging takes a long time.
You can use D-CAN, VAG-KKL409 or something similar.
Some compatible stuff -
https://cartools.lv/Shop/product_info.p ... cts_id=179
https://cartools.lv/Shop/product_info.p ... ucts_id=47
https://cartools.lv/Shop/product_info.p ... cts_id=180
casper1986
- Been thanked: 1 time
hi i have same problem ...
check
pin 2 minus
pin 3 + and
pin 4 kline
need soom picture
check
pin 2 minus
pin 3 + and
pin 4 kline
need soom picture
casper1986 wrote:hi i have same problem ...
check
pin 2 minus
pin 3 + and
pin 4 kline
need soom picture
What exactly?
casper1986
I but k line to pin 1 (wrong place) but if you zoom picture then you see k line is correct location pin 4 i use vag cable and win 7 port 1. You can change port setting (device manager ) i make video .
casper1986
Good!
According to practice COM1 to COM3 may be occupied by some strange system devices like touchscreens, mouse controllers etc. on some laptops / tablets.
If going to change COM port number, better choice is to use COM4.
