Обсуждение: Эмуляторы IMMO, AIR, DPF - документация, инструкции
Brandy-p
Has thanked: 3 times
Postby Brandy-p » 10 Feb 2019, 12:58
Girts wrote:18. BMW EWS4 8HP EGS authorization unit
Применение -
1) проверка правильности SK (авторизация "на столе")
2) создание подменного EGS для ремонтных нужд и проверок
Инструкции по подключению и описаниe в приложениях...
Наверное чуть поже состряпаем и мануал по практическому применению. Ибо на самом деле все эти девайсы под EWS4 обычно не совсем как эмуляторы рекомендуется использовать, а как инструмент для работы (нахождение SK, перепрошивка "на столе" итп.).
ЗЫ: а впрочем - http://www.cartools.lv/Robin/page17.html
I this emulator make 8hpxx gearbox work in m3 e46?
Re: Эмуляторы IMMO, AIR, DPF - документация, инструкции
Postby Girts » 10 Feb 2019, 15:25
You can solve authorization problems. What to do with all remaining stuff is up to you.
Brandy-p
Postby Brandy-p » 10 Feb 2019, 17:30
What you mean "remaining stuff"? Should I expect other problems with fitting this gearbox?
Postby Girts » 10 Feb 2019, 19:51
Brandy-p wrote:What you mean "remaining stuff"? Should I expect other problems with fitting this gearbox?
No reason to answer such question. Because only one option possible - you don't understand what you are trying to do.
Brandy-p
Re: Обсуждение: Эмуляторы IMMO, AIR, DPF - документация, инструкции
Postby Brandy-p » 10 Feb 2019, 20:17
I just trying make 8hp work in e46 so please explain me is this emulator can help me or not.
Postby Daniulis » 11 Feb 2019, 19:33
Brandy-p wrote:I just trying make 8hp work in e46 so please explain me is this emulator can help me or not.
The 8HP emulator is only for AUTHORIZATION, other thing is control. If you know how 8HP to get friendly with your E46 ECU and all other things, then it can help you...
Brandy-p
Postby Brandy-p » 11 Feb 2019, 21:16
Can I buy it already programmed to my gearbox or I need other equipment?
Postby efka » 12 Feb 2019, 12:25
E46 has cno ability to control 8HP. Let me explain it in more simple way. Purpose of this device is to simulate working key signal but there is nothing to control gearbox on your E46.its like merging a cow and a bicycle
Disuhov
Postby Disuhov » 07 Mar 2023, 19:49
Нужно запустить мотор Smart 0.8CDI EDC16C31 2009г. Какой имулятор для этого необходим?
60. Mitsubishi COLT, SMART forfour immo emulator (ETACS), CAN HS
или
62. Mercedes FBS3 emulator ver.2 , CAN
Postby Girts » 07 Mar 2023, 20:11
Disuhov wrote:Нужно запустить мотор Smart 0.8CDI EDC16C31 2009г. Какой имулятор для этого необходим?
или
Естественно - 60. Mitsubishi COLT, SMART forfour immo emulator (ETACS), CAN HS
Этот Твой SMART по сути и есть Mitsubishi COLT в чуть другом чемодане...
Disuhov
Postby Disuhov » 07 Mar 2023, 20:49
В инструкции к 60. написано что для SMART W454 (2004...2006)
На W454 и W451 авторизация одинаковая?
W454 имеет мотор 1.1-1.3i как на COLT.
W451 по мотору больше похож на W450
W450 випускался до 2006 а W451 после 2006
Disuhov
Postby Disuhov » 07 Mar 2023, 21:17
Как найти заветный 7 значный код в EEPROM EDC16C31 ?
Postby Girts » 07 Mar 2023, 21:34
Disuhov wrote:Как найти заветный 7 значный код в EEPROM EDC16C31 ?
Вы требуете невозможного, сударь!
Нет его там.
Он внутри flash.
Disuhov
Postby Disuhov » 08 Mar 2023, 00:28
Мне известно что там виртуальный еепром.
Его вычитать не проблема и область выделенная под виртуальный еепром известна.
Вопрос в том как в нём найти заветные 7 байт.
Postby Girts » 08 Mar 2023, 00:39
Ну начни хоть с того, что дамп выложи... А там разберёмся!
Можно и на почту - info <at> cartools.lv - если вдруг там у Тебя что то сверхсекретное...
Disuhov
Postby Disuhov » 17 Mar 2023, 12:25
Прошу прощения за задержку. Только сейчас смог прочитать.
Return to “CARTOOLS”
