MBcan, MBir, MBkey, MBnec, MBelv... discussion
BIZTeam
Re: MBcan, MBir, MBkey, MBnec, MBelv...
Postby BIZTeam » 06 Mar 2017, 18:30
MB Set received, tried to play with MBE BE Key and some different chinese types.
every time i got Auth Fail! Tried in DS tool, it works.
Maybe i am missing something :)
CHeers
Postby efka » 06 Mar 2017, 20:13
Screen please. I never had any problems with MBE BE keys. Chinese is another story.
BIZTeam
Postby BIZTeam » 08 Mar 2017, 18:39
This is not complain, just feedback.
I think i know whats issue, but only for BE keys, 5V supply to coil. I will test it with EIS coil and 12V, but i must cut that line on PCB where 5v goes to coil.
Every key from video i can program/read with necpro or ds.
https://www.youtube.com/watch?v=6CVnfpSmiiU
Postby efka » 08 Mar 2017, 18:50
Thank you for your video. Self explanatory. Ask Girts but I would rather look into IR trancsiever then start cutting coil.
BIZTeam
Postby BIZTeam » 08 Mar 2017, 19:40
Maybe ir is issue not sure, easiest step is to add my coil, original from w211 EIS. Oscilate it with 12V, 5v line on pcb must be cut. I see NPN gate to coil is ok works without noise.
If that doesnt work i will need quick diagram of existing ir, maybe i can try to add original IR from EIS.
Postby efka » 09 Mar 2017, 05:33
just wait till Girts responds but I would not touch anything as of now. Coil is wound same way on all of these and mine works fine with no problems. BE keys also. I did sell some of them - No complaints from customers. I do have my personal unit on the bench and one for sale - both work identical.
solitaire
Has thanked: 51 times
Been thanked: 189 times
Postby solitaire » 29 Mar 2017, 20:09
Вот здесь брал три BE ключи, mbir читает/пишет/обновляет без проблем.
https://www.ebay.com/itm/142101169065
Цена хорошая :)
Gince
Has thanked: 6 times
Postby Gince » 08 May 2017, 21:55
Привет всем! у меня есть MBcan но в машине не работает - только один раз мог посмотреть hash list. Почему?
Postby Girts » 08 May 2017, 22:15
Если подключатся к OBD разьёму (а не к PT CAN), то очень много вещей можно просто неувидеть или несделать...
anton
Has thanked: 223 times
Been thanked: 56 times
Postby anton » 08 May 2017, 22:35
Всё прекрасно работает.а что простите вы пытались им делать?
Gince
Postby Gince » 08 May 2017, 23:22
anton wrote:Всё прекрасно работает.а что простите вы пытались им делать?
мерседес W221, хочу сбросить 7g Tronic. у меня есть dealer hash, но не могу ввести через OBD. коробка уже в машине... Vediamo?
получил этот список только один раз через OBD:
adr 03 STATUS:
initialized: YES
tp released: YES
personalized: YES
activated: YES
part: SERIES
FBS3 status:
authorized: NO
processing: NO
TEST counter: 00000
LOCKED tracks: none
adr 03 H0: 5C17EC068399CCA9
adr 03 H1: 200E8F1596699128
adr 03 H2: 7FC9D55D80F5DA45
adr 03 H3: EF8035FA3205BF57
adr 03 H4: 2F37FB65483F42FE
adr 03 H5: 8302966EA9E8B9BC
adr 03 H6: 94B4CC821F69D0FB
adr 03 H7: 6D7E35C53687A5FD
adr 03 SH: 4A5272AAEBD07B27
adr 03 TP: C2E901F0EDBA7C5C
adr 03 STATUS:
initialized: YES
tp released: YES
personalized: YES
activated: YES
part: SERIES
FBS3 status:
authorized: NO
processing: NO
TEST counter: 00000
LOCKED tracks: none
опять получить не получается... думал EIS должен уснет...
Postby efka » 09 May 2017, 04:57
залез под авто снял фишку, подцепил 4 провода. Ето вариант первый, Вророй - подошол к колодке с зелёными проводами и там подключиулся. Вот тебе и радость.
X30/21 position nr5
Gince
Postby Gince » 09 May 2017, 14:08
большое спасибо! зеленая провода - chassis CAN, голубая провода - drive train CAN. по моему, мне нужна голубая?
Postby efka » 09 May 2017, 17:33
Синий... не голубой .... голубое небо!!! Да тут он синий... Я по привычке как у спринтерах цвет сказал ну номер колодки именно тот который я написал!
hamzadaw2000
Been thanked: 1 time
Postby hamzadaw2000 » 11 Sep 2017, 05:19
Hello,
how to fix fatal error in w204 ESL using MBelv?
Postby Girts » 11 Sep 2017, 13:01
hamzadaw2000 wrote:Hello,
Very simple.
Use ESL emulator.
Postby Girts » 25 Sep 2017, 22:55
По теме -
MBcan - нарисовались некоторые приятные обновления.
Добавлено - работа с DSM и подобные приятные мелочи.
:crazy:
Качать по прежним ссылкам. Которые, кстати, постоянны и не меняются. В отличии от софта, который всётаки иногда обновляется, и не всегда под обнову пишется аннонс.
Несохранили ссылки? Ну тогда - вайвайвай....
:drinks:
Кстати, кнопу "спасибо" жмякать ненадо.
Лучше уж благодарите талонами на продовольствие или векселями федерального резерва...
hamzadaw2000
Postby hamzadaw2000 » 12 Dec 2017, 19:05
Hi,
W203 EZS common problem with processor, any advice to fix? replace MCU or other ways
Gince
Postby Gince » 12 Mar 2018, 17:03
Hello, MBCAN have V3, can not communicate with diesel ECU CR6P... any thoughts?
Postby efka » 12 Mar 2018, 18:08
CR6p is FBS4 if I am not mistaken........ what car is that?
Return to “CARTOOLS”
