BMW m57 EDC16c31 immo off & emulator
Hekimoglucan
Postby Hekimoglucan » 21 Dec 2022, 22:10
hello forum friends
I bought an emulator from the site, I installed the setup program, but I am getting the no response error
select com 1 with inpa cable...
please help
v
povilas06
Been thanked: 1 time
Re: BMW m57 EDC16c31 immo off & emulator
Postby povilas06 » 23 Dec 2022, 13:10
Emulator installed correctly on ECU? What diagram did you use
Hekimoglucan
Postby Hekimoglucan » 23 Dec 2022, 20:43
k line (ecu 8pin)
ews (ecu 10pin)
+ (ecu 7pin) term 15
- (ecu 2 pin) GND
Connected as AS
inpa cable glows green
light turns off when connection is attempted
Postby Girts » 23 Dec 2022, 21:05
If you are sure your adapter is DCAN (not VVDI, PassThru or anything else) then -
1) if your ECU is from E46, E53, E83 etc - no problems, you can tie both K-lines together.
2) If your ECU is from E60. E65, E70 - better avoid that and work with emulator and ecu separately.
this is due to different communication speeds. Emulator uses older protocols (E38 up). Although it works with ALL ECU's with EWS3 implemented, just alignment procedure is a little different.
solitaire
Has thanked: 51 times
Been thanked: 189 times
Postby solitaire » 26 Dec 2022, 17:47
tested connection EDC16
