FORD 4D immo emulator
Posted: 18 Nov 2022, 10:05
by Canfan
Problem software says error wrong com Port.
But the K-Line interface is on com port 1
any one now the problem?
Re: FORD 4D immo emulator
Posted: 18 Nov 2022, 12:45
by Canfan
i found the fault the 4D emulator software need a USB to serial interface with k-line.
I used the computer's internal serial com port with a Kline adapter that the software does not recognize
Posted: 18 Nov 2022, 23:18
That happens.
Not a fault in software, problem is with your hardware drivers, hardware conflicts or hardware itself.
Standard baud rates used here, nothing exceptional.
Posted: 28 Nov 2022, 09:29
by Canfan
Hello,
the emulator can now be used without any problems, but if I enter the key data in the emulator, but the imo go not off
pssword: 03
users: 00
Key: 0000000000
Seed: 0000000000
resp: 00000000
these are the key data that I enter directly.
Posted: 28 Nov 2022, 13:31
Key 0000000000 ?
Seriously?
Posted: 29 Nov 2022, 10:03
by Canfan
I have a tool to read the key and it told me that
Posted: 29 Nov 2022, 14:49
P4 (KEY PASSWORD) is write only, it is not readable using standard transponder machines.
Although it can be calculated...
Posted: 09 Dec 2022, 10:22
by Canfan
I have test it with another Key with engine control unit
But the imo go not off
Key data from engine controal unit
pssword: 03
users: 00
Key: CDAD024781
Posted: 09 Dec 2022, 11:12
by Canfan
found the error
the diagnostic software gave the wrong key
the correct key is 814702ADCD
