BMW Z3 DME1 EWS 3.D IMMO OFF
damiendarhk
Postby damiendarhk » 09 Jun 2022, 18:02
Hello,
I'm looking for info about immo off on this car
EWS 3.D MODULE
BMW 61 .35 8 384 678
608 377 UTA
HW 01 SW 05
ECU:
DME 1 460 940
BOSCH 0261204420
I can't find the ecu (BMS46) in any emulator; am I missing something? Is it not possible to do immo off on it?
Regards
Re: BMW Z3 DME1 EWS 3.D IMMO OFF
Postby Girts » 09 Jun 2022, 20:00
BMS46 = EWS3
damiendarhk
Postby damiendarhk » 10 Jun 2022, 17:46
https://cartools.lv/Robin/page27.html
I found that step 3 of configuration is required for ews3, but in the SW bms46 button is missing. How must it be configured for this car?
Postby Girts » 10 Jun 2022, 22:54
Read manual once again.
Carefully.
damiendarhk
Postby damiendarhk » 25 Jun 2022, 19:26
I've tryed whitout success.
Wiring is original
Installed emulator inside the ecu.
Removed EWS box.
Cutted EWS wire
Set the emulator for alignment with the sw.
tryed to sync with inpa.
but car not start.
starter motor not run.
Any advice?
Postby Girts » 25 Jun 2022, 22:20
Bridge 2 wires to bypass starter relay located inside original EWS.
Or ask some profi for assistance locally.
damiendarhk
Postby damiendarhk » 26 Jun 2022, 07:31
Tryed also to bypass starter relay, starter motor run but car not start.
Postby Girts » 26 Jun 2022, 15:49
No dumps, what are you actually doing isn't explained, wiring and setup isn't described.
Impossible to help.
damiendarhk
Postby damiendarhk » 27 Jun 2022, 18:35
attached original ecu dump. ews3d, with 15pin connector.
Car did not start anymore after battery change.
emulator is cooncted to pins 33(ews line)-32(k line)-26(+15) of the connector D and gnd of course.
also cutted the wire from pin 33 to ews.
disconnected also the ews box.
Users browsing this forum: tagiruk, Yandex [Bot] and 23 guests
