W210 DAS2 alarm problem
hamzadaw2000
Has thanked: 6 times
Been thanked: 1 time
Postby hamzadaw2000 » 16 Aug 2015, 04:02
Hello.
W210 with alarm and chip system, red LED continues flashing, Center-lock working but RED led flashing, is their any way to bypass as Transponders in both keys OK, i want to bypass alarm and LED immo identify transponder to start car.
with SD4 can not communicate, asking to switch ON ignition, but ignition ON.
thanks in advance
hamzadaw2000
Re: W210 DAS2 alarm problem
Postby hamzadaw2000 » 19 Aug 2015, 11:18
Any advice or help
nemez36
Has thanked: 3 times
Postby nemez36 » 22 Aug 2015, 23:18
If the car with a usual immo, with the chip in a key, it has a priority for shutdown of the alarm system.
If immо active, also works on an IFR channel, to check all connections, power supply of blocks, CAN tire between immо and to an ECU.
hamzadaw2000
Postby hamzadaw2000 » 30 Aug 2015, 04:07
Problem solved, virgin Lucas ECU, install used immobox with key from used car, adapt using DAS.
