ENIGMA wrote:w211_HC12, 287 714, 12/s Rosfar can not read
I know it well, that's why I recommend you to use rosfar pdf for connection with xprog M, and have given you pinout of colors from rosfar to xprogM.
Good luck...
efka wrote:your flash is bad....
Here..... there is everything you need. EIS number is different but it fits your eis. renew engine, esl , make keys for eis (key dumps included) and go on!!!! Or just write my flash into your lock ans try with your keys.
ENIGMA wrote:w211_HC12, 287 714, 12/s Rosfar can not read that's why I used xprog, xprog would not read also, after jerking the eis for an hour or so extal broke off and the eis became readable??? with extal disconnected (I guess it use the other ground as a jumper but now when I try to program I get a verify error... outcome gimaroy... And yes I have been running security bypass for like 45 sec at a time
rosfar read all motorola mcus from eis (all kind of eis) ...need only little thinkkesik wrote:ENIGMA wrote:w211_HC12, 287 714, 12/s Rosfar can not read that's why I used xprog, xprog would not read also, after jerking the eis for an hour or so extal broke off and the eis became readable??? with extal disconnected (I guess it use the other ground as a jumper but now when I try to program I get a verify error... outcome gimaroy... And yes I have been running security bypass for like 45 sec at a time
autolocksman wrote:efka wrote:write my flash into your lock ans try with your keys.
It is the easiest solution, begin with it..
But, to write a flash on this EIS, it MAY BE necessary to disconnect some MCU pins from plate, or remove MCU from plate at all
ecka wrote:я лично р270 читаю и китайский софт говорит от 1 до 3 минут,ну если за мин неуправилься то остановить и заного начать...
efka wrote:check your connections. THere is nothing to lift on that lock. Or just grab that other lock you have and write eprom you saved from this one ( dont touch the flash!) But first verify your connections. This lock is old as earth and all of your tools read and write with no problems unless you killed that motorolla allready.
efka wrote:can you connect to the eis?
efka wrote:Ok..... first just calm down and... You told us that you got another eis with same part number... Correct?
If so read flash from it and write into your eis... it should help. Normaly If I have to write info from lock with same proc - another part number I do eprom and flash.... Both. If you have same part number so flash from other eis should be ok. Info that I gave you is 100% correct and as for me I would simply make keys from info you got, renew ME 2.8 (its childs play) and ESL. That's all. But at this point I believe your situation is helpless....... And why did you have to stick your fingers into that lock? Let me guess.... mileage correction. Am I right?
cheersefka wrote:same eis must have same part number. insides should be the same. your mixed up somewere. And i believe this is your problem. Selecting wrong ecu!. Pictures please from both of them. Inside and out! Or just wait for new eis.
Users browsing this forum: No registered users and 44 guests
