Hello,
I'm looking for info about immo off on this car
EWS 3.D MODULE
BMW 61 .35 8 384 678
608 377 UTA
HW 01 SW 05
ECU:
DME 1 460 940
BOSCH 0261204420
I can't find the ecu (BMS46) in any emulator; am I missing something? Is it not possible to do immo off on it?
Regards
BMW Z3 DME1 EWS 3.D IMMO OFF
- Been thanked: 1930 times
damiendarhk
Re: BMW Z3 DME1 EWS 3.D IMMO OFF
https://cartools.lv/Robin/page27.html
I found that step 3 of configuration is required for ews3, but in the SW bms46 button is missing. How must it be configured for this car?
Read manual once again.
Carefully.
Carefully.
damiendarhk
I've tryed whitout success.
Wiring is original
Installed emulator inside the ecu.
Removed EWS box.
Cutted EWS wire
Set the emulator for alignment with the sw.
tryed to sync with inpa.
but car not start.
starter motor not run.
Any advice?
Wiring is original
Removed EWS box.
Cutted EWS wire
but car not start.
Any advice?
Bridge 2 wires to bypass starter relay located inside original EWS.
Or ask some profi for assistance locally.
damiendarhk
Tryed also to bypass starter relay, starter motor run but car not start.
No dumps, what are you actually doing isn't explained, wiring and setup isn't described.
Impossible to help.
Impossible to help.
damiendarhk
attached original ecu dump. ews3d, with 15pin connector.
Car did not start anymore after battery change.
emulator is cooncted to pins 33(ews line)-32(k line)-26(+15) of the connector D and gnd of course.
also cutted the wire from pin 33 to ews.
disconnected also the ews box.
