Hello I have test the emulator. https://cartools.lv/Shop/product_info.p ... cts_id=206
The problem I can´t get the ECU authorized.
I have found the sync ED360AB2D4341EC3 but it don´t work.
I habe ask a Ford technikan he says me in that car the immo is in the BCU and ABS stored the own sync in the engine contraol unit.
Ford Mondeo SID 206
Ford Mondeo SID 206
- Been thanked: 1930 times
Re: Ford Mondeo SID 206
Change ABS_ID in ECU eeprom to actual one (ascii 529115 in your dump now).
Or if testing on the bench, transmit periodically CAN ID 260 with actual data.
example: 260 (8) 48 E0 37 34 30 39 39 31 -> ABS_ID 740991
Last 6 necessary, not full as shown by diagnostic tool.
I have write the sync code in the emulator and symulate the ABS the the engine will run a short time than i get the fault U0300 Internal Configuration incorrect is a fault from the BCU
