DSC / ASR ABS - BMW&MINI
alclot
Has thanked: 4 times
Been thanked: 1 time
Postby alclot » 20 Apr 2018, 08:21
Hi mates,
Firts post here. I hope help and learn a lot in this forum. Sorry about write in english becuase I dont know russian.
I have question. I´m triying to have diagnostic with ABS/ASR Mini R50 ATE with 47 pins. I was wiring ASR with this pinout but I couldn´t have comunication with it. Perharps do I need like a gateway to do that? I bought 2 weeks ago "CAN Gateway, HS <> FT". I dont know if I can use it to do that.
Thanks in advance ;)
Re: DSC / ASR ABS - BMW&MINI
Postby Girts » 20 Apr 2018, 12:49
Gateway not necessary at all in your case (HS CAN here!).
HIGHLY LIKELY there is a simple K-line wired through dashboard on this car. Car? ...
https://www.newtis.info/tisv2/a/ru/r50- ... ce/s617CSP
In addition - car is designed for minorities, so HIGHLY LIKELY some strange relations possible. Exhaust hole?
Especially if you are going to have deal with MK60.
alclot
Postby alclot » 27 Apr 2018, 06:57
Thanks Girts. Now I have comunication with abs. Car is a Mini cooper year 2003. I have DTC 5df5 and I´m triying to fix it. Very common problem in this kind of ABS.
Thanks again ;)
